1 - 6 of 6 Posts
VTEC Killa!
HELP!!!!!!!!!!!!!
Dude, you don't need to ask this in 3 different threads.
Remove the lower seat cushion by removing the 2 bolts in the front. Then remove the 2 srews on the lower part of the upright portion of the seat. Then lift up the seat, and remove it from the vehicle. You then need to pop the 6 or so clips that hold the rear deck in place....this is best accomplished from the trunk.
Once you pop those out, lift the deck, and there are the speakers.
coffee black and egg whit
OH MY!! :eek: u can definitely change the rear speakres without removing the seats....seems like a lot of extra work just to remove two speakres....
Traded in Alti!!!
Ya take out top portion of back seat, pop clips for inside trunk after u push ur 3rd brake light to the left and up to remove it, now the whole cove will come off and u can access ur speakers, for the tope portion, just un bolt a couple boltrs and lift up hard!
hope i helped, oh ya, u gotta take the side panels off by the top of ur seat belts, makes easier!
1 - 6 of 6 Posts
