1 - 3 of 3 Posts
I've seen a few Altima builds that have the front emblem removed on the stock grille. I was wondering if there is a holder for the emblem, if you need a donor grille, or if it just pops off--overall, the steps required to do this. I'll link a picture as to what style I'm referring too below :)
Thanks!
Easy peasy. I might upload a video guide in case you can't follow it in writing.
1. Lift the hood.
2. Follow the lining of the grill. Notice there's 6 plastic fastenings. 4 at the top and 2 lower than that.
3. Remove the middle part of the fastenings by lifting it just enough to remove the whole assembly. Flat head screw needed.
4. Once that's removed, the grill will be pretty loose.
5. Remove it gently from the bottom, which is connected to the bumper in a hitch kind of way, maneuver it while pulling.
It seems easy enough! If you have time to upload a video i'd appreciate it loads :)
1 - 3 of 3 Posts
