1 - 17 of 17 Posts
One of the most frequent stereo questions I see, regardless of vehicle, are those around installing an amp. One of the biggest parts of that process is running the power wire. I hope this DETAILED how-to of that process will help you if you are at that step.
Tools required:
* Phillips Screwdriver
* Flathead Screwdriver
* 10mm socket wrench/ratchet
* Box Cutter/Razor Blade
* Elbow Grease
Step 1: Unhooking the battery
This is likely the most important step. Unhooking the negative battery terminal will prevent accidental shorting to the chassis, which can fry your equipment! Per texneus' suggestion below (thanks!), it is best to disconnect the negative terminal first (or if you have to choose just one), to prevent a short to the chassis of the vehicle.
  1. Using a 10mm wrench, loosen the bolt on the negative battery terminal, give the terminal a spin back-and-forth and pull the terminal off. Put the terminal to the side of the battery to prevent it from accidentally touching the battery lead during your install.
    (This picture shows the negative terminal being removed. The positive terminal is removed in the same fashion.)
Discussion Starter #2
Step 2: Removing the Driver’s Side lower panel
Removing the Driver’s side lower panel is a good idea before you run wire through the grommet. While you can scrape by without, removing the panel (and a few accessories goes a LONG way to increasing the access to these tight spaces.
  1. First, remove the cover to the left of the dashboard by gently sliding a flathead screwdriver into the crack until you can get a finger-grip on the edge. Pull the cover towards the outside of the car and it will ‘pop’ out.
  2. Next, remove the fusebox cover to the left of the steering wheel to reveal a screw to the right of the fuses.
  3. Once you have removed this screw, you can pull the lower panel off, first from the lower portion towards the seats, and then from the upper section.
  4. Once you have the panel removed, we need to remove some wiring that is attached to the panel. First, remove the lower computer hookup by pushing down on the tab and pulling it out of it’s holder. Next remove, what I believe to be, the temperature sensor to the right of the panel by removing a single screw and pulling it off.
  5. The only remaining piece is to remove the button panel and emergency key reader to the left of the panel. This is removed by using the tabs to remove any button wires, and unscrewing (2) screws, one on the top, one on the bottom. Pull this off and place it on the steering wheel column to get it out of the way.
  6. For maximum comfort, remove the hood popper from behind the lower panel by unscrewing the (2) nuts that hold it to the bracket (10mm I believe).
  7. Once you’ve got all of these components off, you should have easier access to the firewall location.
Step 3: Running through the firewall
While there are plenty of spots to run wire through the firewall, including drilling a new hole and installing your own grommet, there’s a great stock location that will accept the thicket wire you will likely run (1/0 ga). If I can offer any advice here, just be careful, you’ll be working in a tight space with a razor blade, and sharp edges all around. Most likely, you WILL scrape/cut yourself on something, much less if you get too hasty.
  1. First you need to identify where the grommet is. Crawl up under the dash and look up, you will notice that the carpeting ends about a foot up into the firewall and there is some under-carpeting that goes up into the dash the rest of the way. Feel/look a few inches to the left of the Emergency Brake bracketing and you will feel a budge about the size of a tennis ball with some wiring coming through the under-carpet, that’s the grommet!
  2. Get your bearings on where the wiring is coming out, grab your razor blade and start cutting around the grommet itself. There’s not a lot of wires running around the grommet itself, only through it, but be careful! I found the best ‘technique’ was to score a semi-circle around the grommet and then get my hands in there to pull at the carpeting until I had the grommet exposed. The under-carpeting is fairly thick, but it will come out with a few strategic cuts and some pulling and ripping.
  3. Once you’ve got it exposed, again get your bearings on how the wire goes through, grab your razor blade again and cut a ‘cross’ into the lower section of the grommet. I found using the razor blade to get through a few layers and then using a phillips screwdriver to push through was a good technique.
  4. Once you have your screwdriver pushing all the way through the grommet, you can start feeding the wire through. You won’t need a hanger on this one, the grommet is nice and pliable, so you should be able to feed it through from the inside. Once you have a foot or (2) through, walk around to the engine bay and look behind the air box, find your wire and pull your desired length into the engine compartment.
Step 4: Running wire down the driver’s side paneling
Now the wire is in your engine bay to the desired point, you can start running the wire to your trunk (or wherever you are mounting your amp(s)/distribution). Lucky you, the hard part’s over, most of the remaining panels will come up with just a bit of elbow grease, no tools required.
  1. First, remove the running panels (both front and back) by sliding your fingers under the panel and pulling up. Once you have a clip up, slide your fingers down 6-12 inches and repeat until the panel is off.
  2. Remove the driver’s side kick panel by sliding your fingers under the panel and pulling in towards the center console until the clips come out.
  3. The middle pillar does not need to be completely removed. I opted to only remove the lower portion of the panel. Again, this is accomplished by sliding your fingers under the panel near the bottom and pulling in towards the seats. I believe there are (3) clips on the bottom that gave me enough clearance to work.
  4. Now that our panels are out the way, you can start running your wire. For me, I chose to run my wire under & to the outside of the existing wiring. Just thread your wire where you would want to behind the kick panel though, it’s a good idea to use some zip ties to keep the cable in place.
  5. If you haven’t noticed already, there are round clips going all the way to the back under the running-panels. You’ve got two options here: open them up like a clamshell or just run the wire through them like threading a needle. To open them, use a flathead screwdriver and pivot off of the top of the clip on the inner tab (I found a lighter touch worked best here). If you’re having trouble, no worries, there is enough room here to thread a single 1/0 ga wire with ease. Note that the center pillar will have to be threaded, if you did not remove the whole panel.
  6. Once you’ve made it to the rear seat, you will want to lift the seat pan (the butt of the seat) to get the wire all the way to the trunk. The seat pan is easily removed by lifting it a little on the driver’s side and looking for a little pull tab. Pull it and the seat will come up.
Congratulations, you have power! Next Up: Adding a fuse and/or circuit breaker. If I forgot something, I'm sorry, I'll try better next time :boxme:.
GREAT Post!!! Thank you for all the pics.
BTW was there anything you needed to do after hooking the power back up? Was there any lights on the dashboard lit up that you had to do some button pressing to reset? Just wondering as that would drive me nuts...
Thanks!
Thanks!
No problem, I just wish someone had written this up before I did it myself.
As for issues afterwards, I didn't really have any. You will probably have to reset your auto-up windows by rolling them down and then rolling them up all the way and keeping the button held for a few seconds. The only other issue I could think of is that your radio setting will be erased. It's really a no brainer to unhook the battery.
Let me know if you have any more questions.
Do you know if this will work for V6/6spd? I thought that there was no place to run the wire thru an existing grommet and drilling a hole was only alternative.
[*]Using a 10mm wrench, loosen the bolt on the positive battery terminal, give the terminal a spin back-and-forth and pull the terminal off[/LIST]
This is a great post and I'll likely put it to use myself. :woot: HOWEVER...Perhaps I'm sticking my head out by saying this, but Step 1 is just plain dangerous. Never disconnect the positive terminal from the battery until you have disconnected the negative first. If that wrench hits a ground (which is practically anything metal) while you're wrenching the positive terminal you will probably have quite a light show on your hands, and it can go downhill very quickly from there. Disconnect the negative terminal, THEN the positive. Although in reality if you disconnect the negative, the positive can stay. My 2 cents...
A bit old and irritable
Anyone tried this with a 6 speed? About to attempt this - I guess I will find out the hard way if no one replies.
Shouldn't be any different other than having the clutch pedal in the way. What I did on mine is very similar to the method here, but I fed the wire in through the same grommet from the engine side, not from the interior. If you remove the front left wheel and the wheel well liner (takes 5 minutes) there is a lot of room to work with in there. I am 6'4" so the idea of working upside down in a cramped footwell didn't appeal to me.
Great writeup... word of warning
Your writeup was essential to my attempt at this.
Having a manual transmission does throw a monkey wrench into going through the drivers side cabin/kick panel area - there's just not enough room to manuever.
Others have mentioned - but remove the front drivers side wheel well plastic (held on by plastic clips you can pull out and a couple screws in the splash guard area)...
you can look into the wheel well and see the fire wall grommet you need to get into.
Also --- :banghead:
word of warning... do NOT be like me and as you caveman you way into the grommet with an exacto knife do NOT strip any insulation from the existing wires going into the grommet.
I managed to do this somehow and was causing a short circuit which triggered an engine code for the evap control system.
$500 to the dealer to find my f-up. Kind of defeats the purpose of trying to do it yourself. :banghead:
Be careful of the existing wires!
1 - 17 of 17 Posts
