1 - 14 of 14 Posts
New Member to these boards, glad to be here as I love my nissan!
Soooooooooo, after no problems whats so ever my shifter got stuck in park a couple days ago. I left my house and the shifter felt a little stucky but nothing I REEALLY took a notice of. Car drove smooth to the bowling alley met my girlfriend and some friends there. When i left the bowling alley my shifter wouldnt move outta park. I put my foot on the break, i messed with my steering wheel, nothing. I wiggled and jerked it side to side and it wouldnt come out of park even with the hardest wiggle or jerk... i was told try and use something to hit it out of park so instead i just made a fist and popped it outta park. BIG PROBLEM after that, my shifter would go down and through all the gears but it would never REALLY leave the parked gear.... any ideas?
Thanks in advance.
Premium Member
It WAS just a blown fuse, but now, after whoever the asshole was, that told you to "hit" it out of park, you have a major repair bill. Welcome to the forum.:)
Thanks in advance.
well i dont know how massive... i have a couple people looking at it, and temporarily as an experiment we got it to switch gears perfectly with a peice of rope tied to the 2 connecting peices and it shifts but im surely not DRIVING with a ghetto rigged rope thing.... any ideas?
Also, yah the tow truck driver was an idiot lol.
Premium Member
Fuse panel by your knee, there is a fuse that is called iirc Battery Saver. Want to check to see if it is infact blown. I had the same issue....
from taking my center console apart and looking at the gearbox it looks like theres a little plastic clip thats supposed to go into a silver ball... it appears the clip is broken now or there was something else attached to it that connects it to that ball that i broke off.... any idea what clip or peice im talkin about lol
it looks like it connected my gearbox to the link/rod? that leads to my engine/transmission....and when using a peice of rope in place of the clip or watever i can rig it to switch gears....
checking the fuse now...
Discussion Starter #8
hmm very interesting thank you! although i dont see the peice exactly and i dont see the little ball peice i see when i look into my shifter but i think it COULD be the plate lock...
let me explain just a little further o nthe rope i have... i have the rope tied to the rod... if i pull to the left and then switch the gears lightly the gears will shift... because im pullin pressure to the left because a peice is broken that keeps it clamped down and thats the reason i said a clip of some sort. I dont know im sure im just confusing you guys.:banghead::banghead::banghead:
Who wants a body massage?
Um, isn't there a little recessed button on the shifter that allows it to shift out of park even if the brake interlock is broken? Is that what was preventing it from moving?
FERRARI SLAYER
yup..it says shift lock u pop that piece off..and stick sumthin in the hole and it will shift outta park..i had a little piece rigged to fit down in there permanantly for a while lol
Discussion Starter #11 (Edited)
heres what i do know from tampering with it... there is a white plastic peice that has a indent for a sphere at the end of it.... that indent is supposed to snap onto the ball i was talking about which then inturn everything gears correctly.... the problem is when everything is connected properly the plastic indent does not attach to the ball... it comes off and on at will which allows me to move the shifter around at will but never leave park....when i leave everything unconnected and just laying over the place the plastic peice and ball become kind of secure? but not when connected properly? in my eyes something broke off maybe a clamp or pin or something that connected the plastic peice and the metal ball together and actually held it in there.
2006 Altima 3.5SE
If it was the fuse, wouldn't the map lights or dome not work or something? Swear I read that in another thread...
Actually, a few weeks ago my car started doing this too. It would not let me shift into or past reverse (so I'd either get stuck in P or sometimes D/N). At first, it was just sometimes that it would get stuck but then that turned into always.
Heh, I got sick of using a little screwdriver to push the neutral safety switch each time so the other day I grabbed a nice screw and screwed it into the hole on the cover so that it was screwed down and pushing the safety switch permanently. Problem solved. My first car was a 1989 Ford that didn't even have the brake safety at all, so nostalgic!
QUOTE]
I actually had this problem too.
You are correct, your dome/door lights do not work if that light is OFF. I believe fuse #21 (upper right).
good luck with getting a new part....
This is why you should always read the manual.
A "tow truck" guy should have known that virtually ALL automatic transmissions have a shift lock selenoid bypass (that little indent where you stick your key to put it into neutral with engine off, etc).
thanks, 4DZC. My Juke shifter was stuck in park, the PS (power steering) warning light came on and the ICS display wasn't working after reconnecting harnesses I was taking apart searching for a short. I used your advice/info about the fuses in the drivers compartment and I fixed all three above noted problems with just a couple of fuses. Thank you. Can you tell me how to get rid of limp mode in a 2012 Nissan Juke, codes P0101, P0102, P2263 and P0031? I've replaced the MAP sensor, the MAF sensor, changed the CVT fluid, new turbo charger and upstream 02 sensor on the turbo charger. I apologize if this is just an altima site. If it is not any info would be appreciated. Also, the turbo charger I replaced didn't change a thing, so if any of you 2012 Nissan Juke 1.6 liter with a turbo charger owners need an OEM turbo charger I will send it to you for free. My mechanic said it was still tight inside and didn't think anything was wrong with it but the labor cost too much for me to put it back in. Your gain. PM if interested.
1 - 14 of 14 Posts
