1 - 7 of 7 Posts
OK this is my problem. The car is a 95 altima GXE auto. I was driving it and i noticed that there was some hesitations at around 3k-5k rpm's. The car stalled on me 2 times already while driving. I thought it was electrical and changed the sparkplugs and cables also the ignition rotor. It's still has the same problem.
About a year ago the car stalled and my girl took it to a mechanic, and she was told that it was the ignition. They also told us that there was a oil leak from the cam seal. This leak caused the ignition to go bad. Can this be hapening all aver again?? If so how hard is it to do a cam seal??
Any help will be apreciated. Thanks.
Altimaboy
If you are having the same problems as before, take it to a different mechanic and get a diagnosis of the problem. Then take it back to the person who did the work before, b/c he most likely say that it isn't related to the past problem.
Also, why are you driving your car at 5k RPM? Driving like that, you are asking for problems.
We just took the car to a shop for an oppinion. I was the one that did the install of the ignition after that?
Also, why are you driving your car at 5k RPM? Driving like that, you are asking for problems.[/QUOTE]
I'm not driving at 5k rpm's. I had it in park and reving it to past the 3k rpm line and that's where the hesitation comes in b/w 3k to 5k. Thanks for your input and nice avatar.
Any body else.
Altimaboy
This could be related to a number of things like:
FUEL FILTER
WIRESET
SPARK PLUG
CHOKE THERMOSTAT
FUEL SYSTEM PRESSURE
IDLE AIR CONTROL VALVE
MASS AIR FLOW SENSOR
THROTTLE POSITION SENSOR
ELECTRONIC SPARK CONTROL MODULE
I would start with the easy stuff like checking your spark plugs, wires, and the sort
Altimaboy
Oh Yeah, and make sure that your battery has a good charge on it, I know that it sounds dumb, but check it anyway
1 - 7 of 7 Posts
