1 - 20 of 32 Posts
I need 1 sub, under $200 is my limit. my 1,000 watt RF amp will be pushing it. What will it be? Can someone help me out.
i can cut you a good deal on a rockford punch series woofer, 12" or 15" 2 ohm OR 4ohm voice coils. depending on where you live, i can get u a 12" for around 165$ shipped and a 15" for 200$ or less shipped.
o btw, they both handle 500 watts rms, which i'd assume is about what your rf amp is puttin out. it will pound, and since u got a rockford amp will pound even louder=)
You'd lose.
the power the sub gets depends on the impedance it shows the amp. you could get a sub that doesnt see 1000 watts. specify what ohm load the amp does its power at.
the newb
hmm, his amp pushes out 300W RMS, why would you want to power a 900W RMS sub with it? the thing will crap out on him in like 30 seconds, get the Alpine Type S, the Type R is too expensive and has a much higher RMS, you always wanna match the RMS of your sub or go over it, so you're lookin at 200-400 RMS roughly for a sub
You'd lose.
type R goes online for $100, and the RMS is only, i believe, 400 watts. it would be a fairly good match for his amp. Alphasonik is on the same level as Audiobahn.
Sorry i understood from his post that he had a 1000watt RF amp, and also, the type-R rms rating is exactly 300. I agree with CV on this one, type-R would be perfect for his need and power handling
You'd lose.
i know a guy who pushed 450w RMS daily to a ported one, never had a problem. they're a bit underrated...
RJ_21 said:
I was thinking of the Eclipse Titanium 12". What yall think?
RJ_21 said:
Maximum power:600 watts
4 ohm load:100x2
2ohm load:200x2
4 ohm bridge:300x1
The 12" titanium handles 750rms, you only have 300. The eclipse aluminum handles 450 so its a little closer. You don't really have a 1000 watt amp, you have a 300 watt amp that they call a 1000 watt amp (although since even the max isn't 1000 I'm not sure where they came up with that). RMS is important, peak or max really isn't. So you need a sub in the 300 watt RMS range.
1 - 20 of 32 Posts
