stickie time
I just installed a Plenum spacer, and after 2 days, the CEL came on so I had to search around to find the relearn procedure for the 4th gens. So here it is copied and pasted if anyone needs it. I may move it to the FAQ later.Well, Nissan has now totally taken away the ability to adjust idle speed. Aside from making sure that ignition timing is correctly (which really is not adjustable except for a very small amount), the idle speed is programmed into the ECU, is not adjustable, and can only be reset by performing the idle-air relearn procedure. Of course, the idle-air relearn simply allows the ECU to re-discover if the target idle rpm is incorrect, allows it to readjust.
It CAN be done without the Consult, but is MUCH easier for the dealer by using the Consult.
Without the consult:
Perform accelerator released position relearn by NOT depressing the accelerator pedal at all:
1) Turn ignition on for at least 2 seconds.
2) Turn ignition off for at least 10 seconds.
3) Turn ignition on for at least 2 seconds
4) Turn ignition off for at least 10 seconds.
Perform throttle closed position relearn by:
2) Turn ignition off for at least 2 seconds.
THEN you can perform the idle-air relearn procedure:
1.PRECONDITIONING
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
• Battery voltage: More than 12.9V (At idle)
• Engine coolant temperature: 70 - 100°C (158 - 212°F)
• PNP switch: ON (in PARK or NEUTRAL)
• Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, if the parking brake is applied before the engine is
started the headlamp will not be illuminated.
• Steering wheel: Neutral (Straight-ahead position)
• Vehicle speed: Stopped
• Transmission: Warmed-up
• Without CONSULT-III: Drive vehicle for 10 minutes.
- M/T models
• Drive vehicle for 10 minutes.
Without CONSULT-III
NOTE:
• It is better to count the time accurately with a clock.
• It is impossible to switch the diagnostic mode when an accelerator pedal position sensor circuit has
a malfunction.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch OFF and wait at least 10 seconds.
5. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
6. Repeat the following procedure quickly five times within 5 seconds.
- Fully depress the accelerator pedal.
- Fully release the accelerator pedal.
7. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops
blinking and turned ON.
8. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
9. Start engine and let it idle.
10. Wait 20 seconds.
Idle speed CVT: 600 ± 50 rpm (in P or N position)
M/T: 600 ± 50 rpm (in Neutral position)
Ignition timing CVT: 12 ± 5° BTDC (in P or N position)
M/T: 12 ± 5° BTDC (in Neutral position)
Entering the ECU into the idle-air relearn follows the same procedure as pulling fault codes from the ECU, except once the CEL starts flashing, just keep the pedal to the floor. Once it stops flashing and turns solid, let off the pedal and start the engine.
Hope this helps,
Trav
Thankx bro,, do u think this will work on a 2009 nissan altima?What step#3 means is to repeat step#4 five times quickly within 5 seconds.
The idle relearn procedure described in this thread will work for the 2002 to the newest Altimas.Thankx bro,, do u think this will work on a 2009 nissan altima?
Yes, ive clean the TB and MAF and is there anything to fix it, I tried the steps above but still low idle,What forces a re-learn? I ask for the knowledge base, I have no need of it so far on a '17 and '11, they go right back to a perfect idle when battery gets disconnected.
I suspect part of it is moving the TB throttle plate off its' stopped position, thinking ECM has that marked and a change makes it drop idle setting.
Still not working for me,, i have a push button, ive did it over 10x and still low idle.. beside i have a leak in my catalac converter and i did the scan tool (no codes)The idle relearn procedure described in this thread will work for the 2002 to the newest Altimas.
i change the pcv valve and still low idle,, starting warm up goes (rpm 600to 650) then drops when warm to 0 rpm but NO sputteringA clogged PCV valve will try to drag idle lower but TB is supposed to adjust for it.
Cat leak needs fixing, if bad enough that can tilt things wonky. Adds too much O2 and then engine richens idle up to artificially rich.
