1 - 8 of 8 Posts
Breu Meister
Does anyone know the torque specifications for both idler pulleys? I am a tard and forgot to use a torque wrench when installing my idler pulley and am not sure if it is 100% tight...I don't mind jacking up the engine to make sure it is tight enough. I sometimes get a squeel upon startup and now I am thinking it is either the belts are too tight/loose or I need to order the other idler pulley. any help will be appreciated...
Breu Meister
well...yea I just concluded it is the belts. I am going to order a new a/c belt and acc. tensioner pulley. power steering and alternator belt is only 6 months old; Idler pulley is also the same age. Anyways can someone answer me as to what the torque specs are for the idler pulley and tensioner pulley? I really want to know
That torque is for the crankshaft pulley, not the idler pulley.
The idler pulleys are the ones which just sit there and do nothing except keep tension, right?
1 - 8 of 8 Posts
