1 - 13 of 13 Posts
Just go an auto parts store and buy a valve cover gasket set. It will come with the outer gasket and the inner ones for the spark plug holes. It's easy to change . Peace
my valve cover's leaking. never got around to replacing the gasket. gasket cost me $17 from the dealer. leaks really slowly.
Jay
joehotrod said:
what the hell is a valve oil seal??? go to a parts store and ask for that and you'll get laughed at:confused: :confused:
It didn't seem funny to me when I looked over the valve seal replacement procedure in the Altima FSM.
Formerly LordofSearchMod
hahahahahah.. the FSM strikes again...
seriously HotRod.. these manuals have terms only Nissan techs use...
I wouldn't call it a gasket, but you're right, the FSM is a bit precise with its words.
ProChoice=Bottle or Draft
Hahahahahaha, this all sounds really easy huh.
"Just go and buy a valve cover gasket. Throw it in there. No problem"
Well, I thought the same thing. And to tell you the truth it was really easy. Until I was putting the valve cover back on. I broke on the bolts that extrude from the head. So now, I have no idea what to do about replacing that bolt, or even how to replace that bolt.
Damn cars.
how did you break the bolt? don't a whole lotta people take their covers off to paint/polish them? Haven't heard of anybody breaking anything yet.
I'm still wondering about the grease thing...fsm says to grease some points, service dept guy says no.
Jay
Jay
I have no idea how I broke the bolt, I had my torque wrench out, making sure that I didn't over-torque the bolt (cause that's a surefire way to bust one) and the thing just broke in half.
You don't use grease, you have to use RTV sealent. It helps prevent oil leaks.
Damn cars.
dude.. did you do what I told you to do??? take a dremel or drill and make a groove so you can use a flathead screwdriver...
Tape off everything around it with a plastic bag to prevent shavings from getting in the valves... then drill (better with a dremel) a flat long groove. You can then unscrew with a screwdriver...
1 - 13 of 13 Posts
