1 - 6 of 6 Posts
Ok, my car is leaking antifreeze and its not leaking from the water pump or the raidator. I can see it a round the oil pain. On the left side of the header and the right side of the header. The car doens't even have 20,000 miles. :(
It seems to only leak when it cold this my be because it burns it off when its hot. It doenst leak much.
I meant to put this in Gernerl dicussion. I just went out side to check it and I didn't see any leaks. It only seems to leak when its cold and has been sittin for a while. Is the bypass tube medal that goes behind the header. I didn't see any leaks from it.
Erect Member
for now, isolate the problem. tighten every clamp you see. also, run your fingers behind every line you see. if theres a leak, youll come across it.
Hey,
I found my leak it started leaking around 2 oclock and it is the bypass hose. It is wet all over. Gettin green crap on my hand when I rub it. :)
1 - 6 of 6 Posts
