1 - 3 of 3 Posts
I got 2007 Altima 2.5. Recent little front end collision. I bought new driver air bag as it was deployed new seat belts and new grill cause the car still runs fine? Can someone direct me where the front impact sensor is. I can’t seem to find it and I don’t want to put new airbag in and it go off if the sensor is crushed. Thanks
Page SRS-12. Please read the SAFETY instructions at the front of the section. Disconnect battery at least 10min before starting work on the airbag system. This stuff can kill you if done wrong.
If bag has gone off you will likely have to wipe the bag module, they write to the module for the lawyers in court and the system will not work again until the module gets wiped clean and then the factory specs put back in it.
1 - 3 of 3 Posts
