1 - 2 of 2 Posts
hi
I am a newbie with Altimas and I just bought one. It is a 94 GXE auto ( I drive a 5speed CRX usually!) My problem is that the wiring for the air intake temperature sensor is missing!! the sensor is still in the intake but the plug to the harness is missing. can somebody show me how I can splice it back so that it works? I don't know where are the wires. I guess it would be easy to solder the leads from the sensor to the main wiring??? Thanks a lot
Gerald
hard on equipment
Ok, I have a 2000, but the wiring for that should be the same. There should be a bundle of wiring coming from the driver-side fenderwell, it's pretty close to the headlight on mine, not sure about yours. All the sets of wiring will probably be wrapped in black; there's a set of two wires, one black, one red with a yellow stripe. Those are the wires for the sensor. Hope that helps.
1 - 2 of 2 Posts
