Idle Issues After Head Gasket Replacement
Hello everybody, Happy New Year.
Over the Christmas vacation (I'm a teacher) I replaced the head gasket on my 2004 Nissan Altima 2.5 that has ~140k miles on it. I had a very slow coolant leak, and I saw the water on top of cylinders 2 and 3. I also replaced the thermostat, water control valve, all the plugs, and the serpentine belt while I was at it.
Upon reassembly Monday, she pretty much started right up for me and sounded great. After she was running for a few minutes I noticed a very low, and at times, hesitant idle. It didn't jump up and down drastically, pretty much stayed low (600ish rpm) and seemed to almost stall out at times. I took her out for a spin and she drove great, just when I was stopped the idle was funny and the car was jumpy. When I got back to the house after about a 20 minute drive I went through all the relearn procedures. The idle issue never changed. At one point in the driveway it stalled out. After another test drive the SES light came on with a p0300 random misfire code (the same code I was throwing before the head gasket replacement.) I cleared the code Monday night and figured I'd try all the relearn procedures again Tuesday.
Tuesday morning I drove the car to work, a 30 minute, 30ish mile drive, partially on the highway at highway speeds. Everything was fine again while driving, just the idle issues when stopped at a light or whatnot. When I got to work I disconnected the battery. After work I did the release position and throttle valve relearn procedures, drove home to get it to operating temperature, and then once home did the idle relearn procedure. No change, still idling very low and hesitant and occasionally coming very close to stalling.
This morning it drives me to the doctor in the same state, ok driving, funny stopped idle. Around 5 this evening I went out to do a quick leak check and general poking around. No leaks, all seems good. I started the car to get it up to temp so I can continue leak checking while it's running, went inside for about 10ish minutes to get my sons dinner ready, came outside and the car was not running, stalled out. Fired it up again and noticed now for the first time something different. The idle was holding pretty steady at around 1500rpm. Pumped the gas and it would go to 2500-3000, but not past there. Went for a quick drive and it was all funny, hesitant when I was on the gas, jumpy before it would accelerate, and still not really going above 2500-3000rpm. Sounds like what I've read about limp mode being like.
Lastly, I have not had the SES light come on since I cleared the code Monday, or since I disconnected the battery Tuesday. I have about 70ish miles driven since the battery disconnect and no code.
Can stalling out throw you into limp mode?
How do I get out of limp mode if that's indeed what's going on?
What about my idling issue even before this apparent limp mode situation?
Is there something else I should be checking out, sensors or something?
This forum is the best, thanks a million in advance!!!
