I usually jack it up on the rocker seam where you are supposed to put the factory jack, then put jackstands under the k-frame where it bolts to the floorpan.JaySHO said:What are the best jacking points for a 94 altima se? Pictures would be great.
Is the front cross member(Bar under engine) a bad place to jack from?
