1 - 3 of 3 Posts
When Vehicle is running oil mark on dipstick is always low, when off it marks full.
Is this normal? (No leaks found)
Every now and then the Oil light turns on, but goes away.
Is my pressure switch starting to go bad?
If so once I change it, does it need any type or programming after?
Thanks for your help.
Edd
Likely yes. You would not believe the numbers like that I ran into when in parts.
OP, you NEVER check engine oil while car is running, now you see why. Engine off and it needs to sit at least 2 minutes before checking it. No programming after a change. Normally anyway.
They make owner manuals for the likes of you I suggest you get one.
1 - 3 of 3 Posts
