1 - 4 of 4 Posts
Trying to put my rims on but when I put on the front wheel the big bolt in center hub keeps pushing out center caps of the tire is there a simple and cheap work around I hope bc I don't wanna buy a new set
You will need to buy a different type of center cap to fit correctly.
The back spacing you choose is creating this issue.
I have a 45mm spacing and had the same issue.
What rims are you running I have 4 new Konig Over Steer caps that will work for you?
Discussion Starter · #4 ·
im running strada Perfetto 18x8 offset of 40 i was told i could get a 3mm or 5mm wheel spacer and should be good but want that to be my last option
1 - 4 of 4 Posts
