1 - 6 of 6 Posts
Member
is there a way to test your motor mounts when you put ur car in gear is it ok if your engine moves alittle or does that mean its time for new mounts j/w thanks
Erect Member
yes. with the e-brake engaged and the hood open, with the engine running, put the vehicle into "D" for auto or 1st for standard. SLOWLY let out the clutch, but NOT all the way, the engine will rock in a direction if the mount is bad, ANY movement more than a 1/2 inch or so in either direction is bad. put it in reverse to check the other mount. id tell you which diagnoses which, but im tired and not thinking too straight. someone will tell you after i post this anyways.
L4D2 Rage!
Im having also problems with the motor mounts, i went to autozone, they have them for 17 dollars but the upper right one is 170 dollars, how much could be the labor cost to change them, if anybody knows?
Erect Member
diy for free and save yourself some money. not hard to do with a jack and a big breaker bar. SEARCH
1 - 6 of 6 Posts
