1 - 2 of 2 Posts
I have a 99 with a 2.0 in it and was curious if there was any major changes to drop in a 01 2.4 motor, I'm sure the mounts and all will be fine, just not sure on the tranny hook up and electronic components
The Altima model years 1998-2001 used the KA24DE engine. If your engine is a 2.0L, then it's probably an MR20DE or an SR20DE.
If the engine is an SR20DE, then the bellhousing will have to be replaced to install a KA24DE. The ECU and engine wiring harness will have to be replaced.
If it's an MR20DE, not sure if the bellhousing bolt patterns are the same on the KA24DE. The ECU and engine wiring harness may have to be replaced.
1 - 2 of 2 Posts
