1 - 8 of 8 Posts
i recently drained my radiator and flushed it out then a couple of days later i filled it with radiator fluid and went to start it 5 mins later to pull in my garage and it wouldn't start it just made a clicking noise and all the lights flickered everything else in my car still works can you please tell me whats wrong!!!!!!
Make sure all the connections are tight, it could also be your starter. Check to make sure the bolt that hold it down is tight, might not be grounding good.
my batt is brand new someone e-mailed me and said something about the contact points being burnt out if this is so how did it happen????
Evil Member
my car did that too me a couple days ago, the ground on the batt got loose, so i jiggled it a lil and my car started right up
1 - 8 of 8 Posts
