1 - 5 of 5 Posts
my subwoofer stoped working, i tried another one but that didn't work either, the green lamp is lit on my amp. is it possible that my subout on my HU is dead, if so how can i test using a multi meter to see if there's a signal ? where to place the leads, what voltages that i should get ?
Depending on your head unit probably between 1- 4 volts.
You take a multimeter and put the red lead in the hole of the rca jack touching the inner wall and take the black lead and touch the outside wall.
Probably have to set the meter to AC
thanks! one more question: How do i test my speaker outputs of my sub amp to subwoofer, again using multi-meter , where do i place my test leads and what voltages should i be seing between speaker & amp.
1 - 5 of 5 Posts
