1 - 4 of 4 Posts
Hey guys, I have a 2004 Nissan Frontier 4wd 3.3l truck which was leaking oil out of the valve covers. I replaced both gaskets and put everything back together again but now I have a check engine light on. When I run it through an OBD I get a P0327 code and a P0732 code. It drives just fine with no issues with gearing or anything like that. Could it be a faulty knock sensor?
Did you touch the knock sensor while redoing the covers...and do you remember reconnecting it? Usually it's nestled between the two valve covers on top of the engine.
I didn’t touch the knock sensor when I was replacing the gaskets. But it wasn’t an issue before I started work on the gaskets
You likely would have to move wires, maybe they are old and faulted doing it. The knock sensor did not create the trans code, separate issue.
1 - 4 of 4 Posts
