1 - 20 of 23 Posts
Supporting Vendors
Nissan Footwell LED Kit! RGB Multicolor & Single color options! Control w/Phone App!
Looking to add a fresh look to your Nissan's interior? Footwell LEDs are the way to do it! By adding bright LED strips under your dash, you can add a lot to the look of your vehicle.
Diode Dynamics has been producing and designing easy-to-install LED kits for nearly a decade, and this kit is no exception. We have designed new LED strips to be used in this kit, which are highly flexible, IP67-waterproof, and long-lasting. This kit also uses our RGB Multicolor products, which are controlled by the included remote! You can change the color to fit your mood, or adjust the brightness to your preferred settings.
Included in the kit:
  • 2 (two) 30-5050 SMD Strips (flexible and IP67 waterproof)
  • Wiring harness for easy installation
  • 2 (two) quick-splices for installation
  • LED Toggle switch in your choice of LED color
  • RGB Controller Box with RF sensor and 4 outputs
  • Remote Control (choose Standard or upgrade to Bluetooth or WiFi)
  • 4 (four) zip-ties and 3M outdoor adhesive pads for mounting strips
  • 3-year Diode Dynamics worry-free limited warranty
  • 30-day satisfaction guarantee
Also included with rear footwell option:
  • 2 (two) additional 30-5050 SMD Strips (flexible and waterproof)
  • 2 (two) 3-meter (ten-foot) extension wires
  • Additional zip-ties and adhesive pads
Any questions email us at [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks!
Nick C.
Supporting Vendors
can this kit work the multicolor fog lights? like use one controller for both?
Correct, you can control both from the same remote
However, you won't be able to change the colors independently. If your fog lights are on white, the footwell lighting would be on white as well
Nick C.
Super Moderator
Just ordered a footwell kit and few other items for my new F-150 and man, I am very impressed, not only with the offerings but the customer service is 2nd to none! Thanks again Nick and crew. I should have been ordering from you guys all along. Dont worry...we still have the Mazda CX-5 and the Audi RS5 that im sure you will take care of for us.
Very pleased, Lawrence
TATTED1969
Warranty Issues
I have a brand new 2016 Sentra. How would something like this affect the warranty? I'm guessing only if I bought the Nissan Accent lighting kit and had the dealer install it would I be safe. There's a million places around Ft Worth that do lighting but I'm afraid something will happen and they will say it was caused by the install....
Supporting Vendors
Discussion Starter #9
I suggest checking with your dealer first, as many of them handle warranty differently. Some dealerships will use anything as an excuse to refuse warranty services, while others aren't bothered by it.
The footwell kits are easy to install and easy to remove, but I suggest leaving your vehicle stock if you have any warranty concerns
Thank you,
Nick C.
Supporting Vendors
Discussion Starter #20
We're excited to introduce our new RGBW Multicolor LED Strip Kits! These highly flexible, waterproof strips are brighter than our previous RGB strips, and also have an extra white LED chip for a more uniform, pure white color. With our footwell, engine bay, grille, and underglow kits, you can easily add color-changing accents anywhere on your vehicle. Best of all, when paired with our RGBW M8 Bluetooth Controller, you can control them right from your phone!
Check them out in the video above!
1 - 20 of 23 Posts
