1 - 12 of 12 Posts
My nissan murano alternator died last week.
Nissan wanted to charge me $400 to have a new one,several others were around $250-300 range.
I manage to get a cheap one from online for $74 with a six months warranty.
99484
Why such a large difference in price ??
The quality cannot be that different.I think an aftermarket alternator replacement is working fine.
Nissan must be making a huge profit on them...
I've never had an alternator problem before, luckily, but I know friends that had problems and tried with the cheapest new part they could get, and it didn't last too long.
I don't know about good or bad brands or how to identify a good alternator, but even if you can get a bad quality one with lifetime warranty, it's not worthy to change it every five months.
By saying that, I would do research to get a good quality one cheaper than the "Nissan" brand
'The quality cannot be that different.'
You have no idea of how wildly wrong that can be. The problem is one of a whopping size, the aftermarket alts are often broken right in the boxes and price almost makes no difference in rebuilt or new at all. I used to sell them and one of the biggest problems the parts stores have now.
The cheap crap Chinese regulators used in most of them can fail in minutes or a month or a year and usually do.
2020 Nissan Murano S
Don’t risk it, buy a new part from Nissan. If you want to reduce the total price, then you need to reduce the labor cost.
I note as well that if that is a pic shown of the aftermarket alt then likely wrong as most Nissan use clutch pulleys which that one clearly does NOT have. That alone accounts for maybe $100 of the price.
Just replaced the alternator on the 2010 Murano 2 weeks ago and that was a big PITA.
The alternator is very difficult to get out without removing the AC completely, but it's do-able.
Also, the alternator power connector tends to be melted or damaged and likely you'll have to splice the
3 wires to a new connector in a very tight space.
I knew this ahead of time, so I opted for a good brand name, and got a rebuilt Bosch from RockAuto for ~$150.
Here is my video:
2016 Nissan Maxima SL
Are you sure that hte quality is the same? cos I think the only difference is where it was produced and from what materials, that's why I think you should overpay to be sure that it will work as proper and wouldn't brake down the next day
Too bad Nissan doesn't have the parts train Fords do with parts everywhere. I commonly fix those $300 alts with parts often costing maybe $50 max. I've done a couple for as little as 30 cents maybe of solder or simply removing brushes out of one dead regulator to patch them in to another for $10 and the alts then last forever. One I fixed by simply sanding down where it had corroded at an internal ground.
Here is my video:
Why not go out the front instead of dealing with the ac system?
1 - 12 of 12 Posts
