1 - 2 of 2 Posts
For about the last month my 2010 Altima would have power to the climate control and I could run ac or defrost windows then it started to cut out as it pleased with no rhyme or reason i checked fuses good check blower really the little blue guy he's good what do I do besides put a period or comma in this post... Help please...
Vendor
If you've already checked the fuses, wiring and found no issues leading you to suspect the climate control module itself, there could be an internal circuit fault causing it not to work. A diagnostic can be done on it to determine if the unit is at fault.
1 - 2 of 2 Posts
