1 - 8 of 8 Posts
Snow White 3.5 SE
this happens only after i've had my car shut off for a long time...like, more than 5 or 6 hours. (usually, does it when i get in my car in the morning to start it after all night of sleeping).
ok, what it does is,
when i turn the keys, the engine starts, and it's followed by this very short noise/sound which sounds to me like some sort of chain grinding noise. i have no clue as to what it is, and i haven't taken it to the dealer because if i shut off my car and then start it back up, it won't do it. like i said, only does it after i've had it shut off for a long time.
anybody out there having the same problem? (well...wouldn't call it a problem, since it hasn't done anything bad to the car, but...who knows...)
Worship Me !!!
Take it to the dealer anyway.
My guess is that you're hearing the ABS self test.
Former Alty Owner
Why don't you try to record the sound if you can.. and post it on here.. I wouldn't mind hearing the sound.. We might all be hearing this sound to a lesser extent..
Worship Me !!!
javentre said:
...if it only happens on startup it's fine.
Should this be happening at all...I think the answer is no, and if the answer is no then the dealer "should" do something. Or am I just high?!
No, the tensioners are hydraulic .... which means they only provide tension when the oil is pumping into it. It is going to happen when you turn it on because that is when the tensioner in a sense - "turns on" ..... when the oil pressure is great enough to operate it
so the sound is either the tensioner adjusting .... or the tension guide
1 - 8 of 8 Posts
