1 - 8 of 8 Posts
Talib Kweli
My oil pan is leaking, anyone else have this problem?
im thinking i should just try and re-tourqe it, but i dont know if that will work.
Sure its your oil pan, I don't know of anyone ever having to replace their gasket unless it was due to something hitting the pan itself. It might be your oil seal behind the pulley, it is typical for Altimas to have this happen.
Import Tech.
Yep , oil pans never leak on most Japanese cars !! Most likely the front crank seal !!
Ok well my mom used the car this morning and hit my oil pan with god knows what and its leaking. Anyone know a way of getting this fixed, or do i have to get the whole pan replaced? Its pinched like a soda can after you start crushing it.
Shadetree Mechanic
Yes, if it's bent the whole pan needs to be replaced. How does one bend an oil pan? Must have hit pretty hard man.......
1 - 8 of 8 Posts
