1 - 3 of 3 Posts
Car is overheating when driven but not at idle. it is running hot and I stop at a light the temp drops. I replaced both thermostats and changed the coolant sensor. I am getting 4 SES codes p0118, P0300, P0217, and P1217. Only thing I can think is radiator or water pump. Any insight would be appreciated. New coolant was added when thermostats were replaced, both fans are working and car jumps at 2000 rpms possibly due to safe mode
Altima veteran
It should leave safe mode once you clear codes.
Test waterpump: Take out thermostat. With engine cold, disconnected a small coolant hose, start engine, and let it spew into a bucket.
hope thats helpful
1 - 3 of 3 Posts
