1 - 4 of 4 Posts
Shift_PSHHH!
I searched, but no one really discussed this problem. I recently installed a pac-swix controll module to keep my steering wheel remote working, but i ran into a small problem. Whenever i hit a button on the steering wheel it seems to lag a bit before it actually works, If i tap the button and let go then nothing happens, I have to hold it for a sec or two till it works. I know its cause its not hardwired and it uses an ir signal, but if this is abnormal or anyone knows how to get rid of that delay to make it a bit more similar to the oem deck please let me know i would really appreciate it. Thanks.
i think you might be used to the speed sensitive hardwired controls. i dont think your problem is abig deal.
mine wouldnt work unless it was in expanded mode
where is your led mounted that could be the problem
i didnt want to go through all the bs with mine so i ran mine through the kit and it is right by the head unit
seems like it has a little lag though
1 - 4 of 4 Posts
