1 - 1 of 1 Posts
Ok so I have this car 2003 3.5 Altima that is killing me . Symptoms were it died one time then the car will go into limp mode . If I reset the computer by disconnecting the battery it will drive fine for about 1/4 mileand then go back to limp mode has a hard time shifting , won't go past 2500 rpm and loud intake sound .. The car has no codes to give me any direction. I have used a scanner and the gas pedal trick . Things I have replaced are new redline cats, both cam position sensors , crank position sensor , mass air flow sensor , spark plugs , vacuum lines. I'm dying . I bought this car to fix and give it to my brother to help him get back on his feet . Please any help would be appreciated . I'm located in Riverdide ca : 714-6542761
1 - 1 of 1 Posts
