1 - 2 of 2 Posts
Hello everybody, My car is 2008 sentra. The main problem for the outlet is while I plugin a rear mirror record camera is working fine. But after I turn off the car engine and take out the key. The camera still on, It should be auto off while the car engine is off ( I tested the camera in other car is normal and plugin other one of the camera into my car also can't auto shut down ) . So if someone know how to fix this problem please help me , Thank you very much.
Some power outlets are switched by ignition, others are just fused to the battery. Look at the wiring diagram for your make model and figure it out, or find another power source that is switched....like the one that feeds the radio.
1 - 2 of 2 Posts
