1 - 3 of 3 Posts
Greetings,
Here are the symptoms...
1) I've had a power steering leak for 6 months. I've added a quart every month, and I just topped it off.
2) A couple weeks ago, there was a ticking from my engine. It speeds up when I speed up, and continues at idle. It has gotten more pronounced over the last few weeks.
3) I just went to get an oil change because I heard that can alleviate tensioner problems temporarily, and when I got home a couple hours later, after driving say 20 miles, I started to make a sharp turn into my uphill driveway, and a loud clanging noise began to occur. The car did not jolt or anything, but when I backed up and tried it again, even a small turn in that direction did the same thing. I tried the wheel in the other way, and it seemed fine. The power steering fluid is not low. Slightly low yes but not low.
I should also add that when they had the car up on the rack, they mentioned it was a power steering hose leaking a lot.
Whether it was timing, or they yanked something, I'd love to hear the possible things to look for. What should I check first? Power steering pump? Tensioner? Or possibly both at the same time?
Thanks a bunch
Adam
2006 3.5L SE-R Altima
To eliminate the power steering system, remove the front belt for the power steering from the engine. Start the engine and listen for the loud clanging noise; move the car around a bit and turn the steering wheel a little to see if there is any noise.
All in on the PS pump.
1 - 3 of 3 Posts
