1 - 3 of 3 Posts
OK before anyone bites my head off, I did search and found some info but I'm still a lil shady on why it is that the power steering fluid that I put in about 2 months ago isn't working. The same whining sound has appeared again. So what is the exact kind of power steering fluid that I need and WHY does general fluid not work in the first place?????
It takes regular power steering fluid - 10w30
Joke. hehehe. :)
Fluid is not working... That's interesting, did someone cancel the laws of nature? :)
Spray some WD40 on the belt, and listen is noise is going away.
I have no clue how much the pump would cost...
Pacman
I would check the belt for proper tension and wear and you may wanna use STP belt dressing (1.99 at AutoZone). Perhaps you have a leak? I don't know how often you have been checking the fluid levels.
1 - 3 of 3 Posts
