1 - 7 of 7 Posts
Robert303
Hello everyone, I am a new member & posting for the first time.
I will try to make a long story short:
A few months ago I bought a used 2000 Nissan Altima, shortly thereafter I noticed when I turned the AC on my car would die. I had a mechanic replace my Idle control valve. After this repair it started dying a lot more often, wether I had the AC on or not.. So at this point I took the car to Nissan dealership here locally for a $100 diagnosis. After two days I asked them what was the problem & they stated that when the tried to look at the problem he plugged something into the ECM & it started smoking like it was burning. I could go further here but won't for the sake of what I want to ask.
So Nissan offered to fix my car if I bought the part (ECM), so I bought a 2000 ECM off of EBay. Nissan stated that the part wasn't right as it looked different.
They suggested that I look at my registration, I did & the reg says late model 99. At this point I took not one but two 99 ECM to Nissan & the stated that the key couldn't read the ECM. Now they are suggesting that I get A 2000 ECM again. Here's my question how do you know how to reference the part numbers on a used ECM? My ECM had a WG on it & I have bought an Hh,Hk,Wt. any ideas? Thank you for reading my post..
You mean like this one?
So that tells me the Nissan WG unit has part number JA18P 67ZA3, Other ID 5ZE1WG and Interchange
Robert303
Your Exactly Right!
DOUGMAC1, how did you know that? More importantly why can't Nissan service direct me on how to order a used part with the right numbers? I met with the service manager & a mechanic & they have no idea what any of these numbers mean, & neither do I. They can tell me what the part number I need if I buy a new one, but can't afford a new one being on Social Security. Can you help me understand how to order a used part & what numbers I need to focus on to get the right part?
Why not just buy the one I linked to above? (ebay $125 + ship)
Search on the part string I gave you: JA18P 67ZA3. This should be verifiable by the dealer parts counter by looking up the ECU based on your VIN (off your registration paper/pink slip/whatever). Many Nissan ECU's were made by Hitachi, especially likely for the ones with the large 2-letter codes. I believe the WG specifies the software load in the ECU which is slightly different depending on what options you have (like auto/standard transmission).
FWIW the part number shouldn't change just because it's 'new'. What part number did they tell you that you needed?
Robert303
Discussion Starter · #6 ·
Heye D0ugmac1, I am still curios as to how you know the parts numbers? Secondly, what do any of those numbers mean? Example WG, *5ZE1WG*, or JA18P67 ZA3 9203? Not one person, either in service, or mechanic had a clue as what any of those meant. My car has been @ Nissan for repair for 10 weeks..
No magic, I used Google images. I found a hit for a used ECU for an '00 Altima which referenced the WG code which you stated was on your original ECU--which is the key differentiator amongst sub-variants in Nissans, at least based on a similar investigation I did for M-Train in his 300HP NA ('05 S-ER) thread--hence the large bold CAPS.
The image I found, turned out to be that part you bought...and from the images provided by the vendor, was able to read off the other codes. Most Nissan part numbers are a pair of 5 character alpha-numerics ie A1A1A-1A1A1 to which the JA18P-67ZA3 maps. I found other older model (mid-late 90's) Altima's which had ECU's starting with prefix JA18 at which point I was confident that I had found the correct one. Searching on that yielded several more parts that also correlated to an '00 Altima. I suspect the 5ZE1-WG is the mfr pn.
1 - 7 of 7 Posts
