1 - 1 of 1 Posts
Formerly LordofSearchMod
straight from my 1999 Service Manual...
1)close all doors and locks
2)Insert and remove the key from ignition cylinder more than 6 times within 10 seconds (hazard warning will then flash) at this time all original id codes are wiped
3)Turn ignition switch to ACC position
4)Flash any button on the new remote control ONCE (hazard lamps will then flash) at this time, new ID code is entered
Do you want to enter any additional codes? (Max of 4)
YES: Release the door lock, then lock again with door lock/unlock switch (in power window main switch) Then Repeat step 4
NO: Unlock driver side door and open driver side door (END) Check operation of remotes
1 - 1 of 1 Posts
