1 - 5 of 5 Posts
2006 Murano SL runs great when programmed but each time the ignition switch is turned off it will not start again and has to be reprogrammed
KSIGH
what are you programming each time?
The mechanic is programming the ECM and the intelligent key fobs everything will work car will start fobs will open and lock doors but if ignition switch is turned off the memory is erased fobs will not work and car will not start
Ok, so the fobs are stored in the BCM/NATS. So if it's losing that when the ignition is switched off, you need to determine if the battery feed is still working at the BCM...if yes, replace BCM, if no replace fuse/fusible link.
1 - 5 of 5 Posts
