1 - 9 of 9 Posts
i'm looking to get the l7 kicker subwoofer and realized the have them in 2 or 4 ohms.what is the difference between a 2 ohm or 4 ohm
subwoofer?
thanks
a for ohm sub will sound better in my opinion, i have the he2's in 4 ohms running my amp in stereo and it romps. even so with my thirst for more i want to upgrade to the L7's so let me know where you get them.
Mike
There is no difference in sound between them, the only difference is going to be the load that the amp sees, so you should just get the ones that best fit the amp.
Local Guamee...
IMO, the L7's are DVC's, which means either 2-2ohm's or 2-4ohms. Like what rthompson said, there is no difference in sound. It really depends on what your amp recognizes them as. I have a L7 8" 2ohm. I run it parrallel which breaks it down to 1ohm and use a 1ohm stable amp. This is the maximum power for my amp (1ohm), so this is why I do this.
It really depends on your amp and what it can handle. If you post what type of amp you're going to use, we can probably recommend how to hook it up for best performance.
Simply put, you will **usually** get about double the power at 2 ohms vs 4 ohms. The less ohms you have, the less resistance. Like said previously, you should probably want an ohm load that matches your amplifier. Since most sub amps are 2 ohms, you'll probably be well off getting a dual 4 ohm L7 and running the wiring in parallel (that will give the amp a 2ohm load).
the amp im using is the kicker stillwater designs 1000 watt amp.
in that case, you will want to get the Dual 2 ohm version, and wire stereo, or series bridged. :)
1 - 9 of 9 Posts
