1 - 11 of 11 Posts
Hi, I tried installing my indiglo guages yesterday. I got them to work and looks great, but the back lights (for the air, guages. etc..) won't light up. I tried fixing it today, but now the indiglo won't work. So now I have to choose between keeping the indiglo or the lights.
I attached the red wire from the transformer to the red/ silver wired on the dimmer. Does anyone have a similar problem? Thanks.
Got Salt?
I had the same problem, don't hook it to the dimmer. I ran the wires to the front corner lights and haven't had any problems yet
Where's the front corner lights connector located? Is the red wire long enought to reach it?
Got Salt?
I had to add more wire, but I spliced into the signal wire just behind the harness. I don't know exactly which wires connected to what, just touch them and see if they work, it won't hurt anything
So u mean I'll have to cut the signal wire and attach it back together with the red wire from the tranformer?
Like a Villain
i connected the black wire (indiglo) to the black and silver wire, then the red wire (indiglo) to the blue wire and they work fine
Got Salt?
I didn't cut the wire, I used a razor and carefully shaved the insulation off from around the wire and wrapped the indiglo wire around it and taped it
Resistance is futile
Seth_Rash said:
I put my indiglos in and at first the were really bright but they dimmed down a little, has that happened to anyone else?
Every time I push the brightness button...
THe red wire from the transformer goes to the red wire with blue stripe on the dimmer switch. THere are two other red wires with wellow stripes. I don't know what the silver dashes are for, but that doesn't distinguish one red from another. You need the one with the blue stripe.
1 - 11 of 11 Posts
