1 - 8 of 8 Posts
I just got my berk intake and the elbow is bent like someone dropped it or something. There is no gasket for the elbow MAF? seems if there is no gasket they have to be pretty straight and flush or when I tighten it down I may break the edge tab on the MAF. It came with two gaskets but one seems to not fit anything? Anyone else run into this prob?
say when.....
Dubz:
If I remember correctly, the only gasket is the one that is placed where the filter and the elbow connect.
If you need help, pm me and I will give you my #, and will walk you through.
I just ordered the Berk intake for my 05 3.5! I'm excited! Can you tell me anything about this Apexi filter? It sounds like it is a paper filter but I don't know. Where do you get replacement filters when you need one? Is the installation easy? Thanks in advance!
^^APEXis are 100,000 mile filters......
Installation is a snap!
I put the whole thing together before I even raised the hood. Now all I recieved was the elbow and filter. I already have the frankencar midpipe.......
The Ricenator
The freaking filter costs 85 bucks alone....
It had better last 100k miles.
As to skepticism, only one way to cure that... try it yourself! The dry filter needs no oiling and just needs to be cleaned every now and again. I have had no problems with mine, but have only had it for 4k or so miles.
NBTX05Altima said:
A 100,000 mile air filter!? OK...I'm skeptical.....very skeptical!
Well get K&N....
I have had it for about 30K miles and have cleaned it twice by using a vacuum cleaner and pressured air. The filter maintains its level of performance.....
Once you have one of these filters in your hands, you'll know that you have quality! ;)
1 - 8 of 8 Posts
