1 - 9 of 9 Posts
VTEC Killa!
what is a constant 12v source that kills with the engine
enlarged member
Check the fusebox with a testlight - there should be a radio fuse (and several others) that are acc only (meaning only on with the key in acc position).
Note - be careful that whatever you are wiring does not add too much load, the fuse may blow, you may need to use a relay to draw from the battery or a constant 12 volt source.
VTEC Killa!
Discussion Starter #9
power convertor dc-ac
1 - 9 of 9 Posts
