1 - 6 of 6 Posts
Rockin the Kasbah
I was looking at everyones turbo setup and realized on how crappy it is to have our stock rady hose curve right towards our downpipes....
So I figure why not find a solution to this problem...I ended up making a flange out of some flat stock, found 1 3/8 pipe, welded the two together, and then cut out the hole in the flange (if I were to cut it first, it certainly would have warped)
Mind the pics, like before the car is soooooo crusty from work...just look at the results
(Note to Mods: I know I've double posted this, I just think it's somethign that can get genuine opinion on in this forum, and run of the mill discussion on in the general forums -- thanks!)
Turbo Motorhead
pretty ingenious, but how do you plan to access your alternator connections, just humbly asking? is there enough room, cant tell from the pic?
Rockin the Kasbah
All are easy to get to...plus I'm using a steel reinforced flexible radiator hose, so I can also bend it a lil as well to access it...
1 - 6 of 6 Posts
