1 - 2 of 2 Posts
Hey so last week my 1999 R34 auto sedan non turbo skyline started to miss fire, I was told to replace the coilpacks and while I was in there I decided to hange my spark plugs as well ( they’re brand new splitfire coilpacks and Bosch Double platinum spark plugs) and the car is still missing, it was worse but after replacing a moly in the manifold I had forgot to put back in it’s running a little better but still has the miss, could it be a faulty coil or spark plugs or both, or could it be the coil harness?
I’m still learning a lot of things as I go and can’t figure out what could be causing the issue if you need any other info just let me know, thanks in advance
If the splitfire is the brand I'd suspect them in a second. Splitfire has always been junk in a fancy package where I come from.
1 - 2 of 2 Posts
