1 - 3 of 3 Posts
Here's a zipped pdf of page out of the 2001 FSM that shows the parts of the rear axle. This board doesn't allow .pdf attachments sp so I zipped it.
As you will see, it shows it with the drum and disk brake parts.
With a non-ABS system, another thing to think about is a master cylinder/proportioning valve swap with one from a SE for correct brake fluid pressure.
What else would need doing besides calipers?
Tofu Shop Owner
I don't think you need anything else (besides the caliper). Everything looks very straight forward. According to the diagram, you don't even need new knuckes. And if you have a non-ABS, the conversion is even simpler! I think the tricky part would be the parking-brake mechanisms/cylinders.
Good call. I think both control cables would have to be replaced. The connection to the brakes looks like it's integrated with the cable. It's a different connector for the different type of brake.
1 - 3 of 3 Posts
