1 - 3 of 3 Posts
Rockin the Kasbah
I was looking at everyones turbo setup and realized on how crappy it is to have our stock rady hose curve right towards our downpipes....
So I figure why not find a solution to this problem...I ended up making a flange out of some flat stock, found 1 3/8 pipe, welded the two together, and then cut out the hole in the flange (if I were to cut it first, it certainly would have warped)
Mind the pics, like before the car is soooooo crusty from work...just look at the results
(Note to Mods: I know I've double posted this, I just know that it wouldn't widely be seen in the turbo only forum..thanks!)
Rockin the Kasbah
I know, but I was bored and was playing with the arc welder...
This way I don't run into problems in case this were to not work....
I'm gonna get a nice one made up in aluminum and tig welded together eventually...but I wanted to test this now...gotta go wipe off that silicon!
1 - 3 of 3 Posts
