Right now I have to turn on my amp from a switch. The remote wire goes from the batt. to a switch, then to the amp. I have no remote wire on my h.u., so where can I connect the remote wire so it can turn on at ACC and when the car is on?
try that, it should work. the ignition is what turns your deck on and off with the turn of the key.jared18 said:i believe you can hook the remote wire to yout ignition wire. i used to have my cb radio hooked up to the one under my dash
that should work. just splice the two together.95_XE said:Thanks for the suggestions, I might go for the cig lighter. If I connect it to the power antenna wire it'll only turn on with the radio, not the cd. And if I go with the ignition, I won't be able to run my amp while the car is off.
I wanna know how to wire off the cig lighter. I still need the cig lighter, so do I just cut the wire and connect both the cig lighter and remote to it?
