Hey Thai. If you want to use your steering wheel controls find the harness that plugs into the original head unit from the steering wheel when you get it out of there. Use a meter to identify ground and which wire corresponds to the closing of each switch on the steering wheel. Then open up your new head unit and identify the wires or traces from the corresponding switches on it and solder the steering wheel control wires on in parallel. You will need a new connector and/or ribbon cable to pull this off. Requires some electronics experience. Both the original controls on the faceplate and the steering wheel controls should then work if the volume is not a knob. All controls should be switches nowadays.
