High/pulsating idle, after disconnecting and reconnecting electrical connector to throttle position controller such as when cleaning/replacing throttle body.
TOOLS NEEDED: stopwatch or timer showing seconds.
Accelerator Pedal Released Position Learning
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch ON and wait at least 2 seconds.
3. Turn ignition switch OFF wait at least 10 seconds.
4. Turn ignition switch ON and wait at least 2 seconds.
5. Turn ignition switch OFF wait at least 10 seconds.
Throttle Valve Closed Position Learning
2. Turn ignition switch ON.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning
1. When engine COLD, first perform the Accelerator Released Position procedure and then the Throttle Valve Closed Position procedure.
2. Drive the vehicle for at least 10 minutes to make sure the engine/transmission are fully warmed up. Make sure the battery voltage is more than 12.9V at idle.
3. Put vehicle in Park, turn off all electrical powered stuff, wheels turned straight.
4. Turn key OFF and wait at least 10 seconds.
5. Confirm that accelerator pedal is fully released, turn key ON (not ignition) and start stopwatch at same time.
6. When stopwatch is at 3 seconds, fully press & release accelerator pedal 5x hard and quickly.
7. Wait 7 seconds, fully depress the accelerator pedal and keep it down for approx. 20 seconds until the MIL stops blinking and turns ON solid.
8. Immediately start the engine and let it idle. It may still likely be a high-rev/pulsating idle.
9. Let it run for about 20 seconds and rev the engine several times.
10. Operation should now be normal except MIL may still be on. It may disappear soon on its own, or you can do the following:
EASY RESET OF Malfunction Indicator Light (MIL)
1. Turn key OFF and wait at least 10 seconds
2. Turn key ON (no ignition), wait 3 seconds, then press & release accelerator 5x hard and quickly.
3. Wait 10 seconds, then fully press accelerator.
4. After about 12 seconds MIL will go off then start blinking. As soon as it starts blinking, release the accelerator.
5. Wait 10 seconds, then fully press accelerator again.
6. Wait 10 seconds, then release the accelerator again.
7. Turn the key to off, then immediately start the engine. The MIL should be gone now.
