1 - 10 of 10 Posts
I have a 96' Alti and I wanna buy bigger rims than the standard 15's. I guess this would go with any car you decide to do this to but would you have to re-calibrate the speedometer to account for the difference in more inches to the ground?
PrOuD To Be HaWaIiAn
nah it won't make that much of a difference. i put 17's on with 215/45/17 and i can't tell the difference one bit.
R.I.P. 97 Altima :(
Since the car wuz only geared to have a 15 when you increase wheel size the speedo does go off. But not very much if you did a 1inch or 2inch increase. If you went up to a 18 + you really should get the speedo recaliberated.
Beantown Punk
well also you have to take into account that 15s have a much higher profile tire, than the 17's. since the 17's get a smaller profile tire the difference between the two is negligible.
Where's a decent place to buy rims, online or magazine, it doesn't matter. Package deals would be nice, and I don't know if I can trust e-bay??????
not necessarily. if you do a search someone posted up a speed calculator where you can input your wheel size and it'll show the adjusted speed. difference for me was like +1.5 mph
belongs -> @ltimas.net
Official Troll
EEEEE, wrong! Sorry, but you go home with nothing. Thanks for playing.
1) Read everything in the Tire Tech section of Tire Rack
http://www.tirerack.com/tires/tiretech/general/sidewall.htm
Pay particular attention to the section on "plus sizing"
http://www.tirerack.com/tires/tiretech/general/plusone.htm
2) Use one of these tire size calculators to determine what tire will be equivalent in circumference to your stock tire.
http://www.miata.net/garage/tirecalc.html
http://www.paspeedo.com/calculator.htm
3) Since you're probably not going to use the tire calculator (cause I know that you're going to come back and say "Hey, so what tire will fit on my Altima without throwing off the speedo?"... here's your answers
195-65-15
205-60-15
205-55-16
225-50-16
205-50-17
215-45-17
225-45-17
Official Troll
Ome more thing...... wrong forum.
1 - 10 of 10 Posts
