Product:
Shackle
Retailer:
ROBBOR
Discounted Price:
$34.20 USD 4% Saving was $35.99 USD
Valid Until:
Sep 30, 2022 Expired
N/A
Deal Link:
***Subscribe to get the coupon.
Font Musical instrument Art Fashion accessory Circle
This clevis Mount is an industry standard Heavy Duty Design Comes with 1/2 inch Shackle and completed Hardware including Grade 8 Galvanized Bolts with Washers and Nylon Lock Nut .You can work them together or you can pick up these 2 pcs 1/2 inch D ring Shackle for other purpose. Its 1/2 inch size, Hot Dip Galvanized Screw Pin Anchor Shackle. Black powder coated. Working Load Limit: 2 ton. Threaded shaft for easy installation - can be mounted on any tow point location
  • Features
  • Pad Eye is Weld-on
  • Backer Plate Dimension 1/4" Thick 4.25inch Length x 3.25inch Width
  • Mount is Zinc Chromate Plated
  • 1/2 inch Black Chrome ,Power coated Gloss Black finish
-Every Mount Includes 1/2" x 1-1/2" Grade 8 Galvanized Bolts with Washers and Nylon Lock Nut
MPNRB-GH21S
TypeBolt on Clevis Mount
MaterialForged Steel
Surface FinishZinc Chromate Plated
Plate Thick1/4inch
Plate Dimension4.25" x 3.25"
Shackle1/2 inch
Bolt1-1/2 INCH Grade 8
Pad Eyeweld-on the plate
HardwareYes
