Check this out!dflosrt4 said:please relay the message. I work for a nissan dealership all the time. I have seen oil pressure switch problems but more than likely thats not what it is. It the rear timing cover gasket. We have seen it numerous times. remove the oil pan and there should be a peice of gasket in there. You have to replace the rear timing cover. They blow out and cause low oil pressure. I have seen it so many times. If people drive on low oil pressure it can damage the engine. Please relay this message on the boards. I cannot post for some reason. Thanks
