I wonder where that piece o gasket came from?
Very nice. If I ever have that problem, that will be the first place I'll check... Nice.Here are some more pictures of the gasket. If you guys are ever experiencing low oil pressure and find a cardboard gasket piece in your oil pan this is the problem. It's not the rear timing chain gasket. It's this.
Ty for the quick response. I will bump the weight up and I do baby the car. I appreciate the quick response!!Bumping the oil weight up may help, from 5-30 to 10-40. The engine has wear that does that; commonly in the DOHC head.
Oil pressure switches commonly are set from 5-7 psi, engine wears to be under that and the light then flickers on at low idle in summer. You used to be able to simply bump the idle up to get rid of it but modern electronic will not let you bump idle up.
Don't hotrod the car; it may last for years yet, I drove one that did it for many years and no trouble at all.
